french Posted November 9, 2018 Report Share Posted November 9, 2018 HELLO I acquired a xvostick 60 for over a year, I will replace the chip, my GND terminal is not connected only my terminal B- is connected to - the battery and the body of the housing and the connector - pin510, does this pose a problem? GND IS CONNECTED TO B-? THANK YOU, thank Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted November 10, 2018 Report Share Posted November 10, 2018 That's how they're manufactured. They're utilizing the common GND of the body/batt- to obtain the 510 GND. Perfectly OK to do as long as the 510 GND to body GND is SOLID (low resistance). TLDR......yes that's fine. 1 Link to comment Share on other sites More sharing options...
french Posted November 10, 2018 Author Report Share Posted November 10, 2018 HELLO thank you, I had a problem, I can not get down the cut of my battery to 3V with analyze battery on escrib, I've all tried my chip cut of the battery at 3.9V, I vap on 1 OHM at 15W, so I was wondering what's the problem? if anyone could help me and thank you again Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted November 13, 2018 Report Share Posted November 13, 2018 Can you post a screen shot of Device Monitor while firing the DNA 60 Xvotstick at 15w? Make sure the battery box is checked. Let's take a look at the battery sag under load. Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 Hello, I just changed my chip, when I fire my battery gauge weakened, I vap 15W and falls to 5W, there is a problem, that's why I changed my chip, how to fix the problem, thank you Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 can you explain to me how to record my fire curve in monitor system, when I record it gives me exel-shaped table,thank Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 This is done using a tool in Windows called "Snipping Tool", it is in Windows Vista and later. Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 I set as the file EV.ecigprofile Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 I set as the file Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 my setting Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 If your hoover your mouse on the line marked by arrow in Device Monitor it will show what the voltage is. What does it say? Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 I vap kanthal and no TC ,and thank you for snipping tool Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 At 15 watts you should be getting very little voltage drop . I'd be looking at the cell it's self, have you tried another battery. Check closely the battery holders contacts, wire connection to contacts, ect. Edited to include the word "drop" Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 2,76V Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 Check my last post., power isn't making it to board properly Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 Everything is well connected, the box worked well when I buy it and suddenly it does that, I change the chip and it remakes the same problem Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 The problem appears to be with battery, battery holder, wires from battery holder to board. How is the ground connection done on the negative side of the battery? is it a chassis ground or wired. Clean the battery caps threads and the threads of the mod with alcohol (if it has this) Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 I ask myself if the cutt of the battery is too low, 2.75V set by evolv Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 No, as that's about as low as you want it to be set to. With a 15 watt load on a full charged battery your voltage drop should be almost 4 volts. Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 am going to look at this or can connect the gnd on - pin, which is odd is that it worked originally without gnd connected Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 Make sure to try cleaning battery cap threads and the threads that the cap screws into with alcohol and q-tip. I've seen same problem on other mods before where the threads of the cap were the problem even though they appeared clean. Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 I cleaned and recovered my battery cap, I found a piece of plastic hidden under a cap by cleaning with a cotton swab and walking, I thank you very much. on dna my favorite chip, I hope the problem is solved, thank you again 1 Link to comment Share on other sites More sharing options...
french Posted November 13, 2018 Author Report Share Posted November 13, 2018 The problem is back, tomorrow I dismount the box and I look at the problem of gnd and body mass, I'll let you know, I think the problem you talked about contact must be hurt; Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 13, 2018 Report Share Posted November 13, 2018 Look very closely at where the B- wire of the board connects to the mod's body. Link to comment Share on other sites More sharing options...
