Feature request : add profile ID in saved puffs log
Struktur
With “Save all device puffs“ in Device Monitor, you get a file with 20 fields. It would be helpfull to add a field with “Profile“ ID (and/or Profile name).
* Puff
* "Date/Time (GMT)"
* "Date/Time (Local)"
* RTC
* Recorded
* "Board Temperature"
* "Raw Ohms"
* Time
* Energy
* Power
* Temperature
* "Peak Temp"
* "Coil Loss"
* "Room Temperature"
* "Ground Ohms"
* "Power Setpoint"
* "Temperature Setpoint"
* "Cold Ohms"
* "Cold Temperature"
* "Static Ohms"
  • 2 months later...
Where can I find "Save all device puffs" ? On device monitor does not exist. I have a DNA 250.
13 ore fa, Wayneo ha scritto:
DNA250C (Color screen)
Unfortunately there's not this function for DNA 250 as you can see. Is it possible in some way, to use this functionality also for the standard DNA 250?
Can you send the resulting output file?
Edited by Gnagnom94
You are correct, and why I specified 'color screen'. The color screen 250 saves those fields as a delimited csv file for each puff. AND with much more precision than the non color 250 using 'save all data'.
Not that I'm aware of, although there is a 'Data Aquisition' option in the 'Research' tab but I haven't played with it.
