Struktur Posted September 19, 2018 Report Posted September 19, 2018 With “Save all device puffs“ in Device Monitor, you get a file with 20 fields. It would be helpfull to add a field with “Profile“ ID (and/or Profile name). * Puff * "Date/Time (GMT)" * "Date/Time (Local)" * RTC * Recorded * "Board Temperature" * "Raw Ohms" * Time * Energy * Power * Temperature * "Peak Temp" * "Coil Loss" * "Room Temperature" * "Ground Ohms" * "Power Setpoint" * "Temperature Setpoint" * "Cold Ohms" * "Cold Temperature" * "Static Ohms"
Gnagnom94 Posted December 14, 2018 Report Posted December 14, 2018 Il 19/9/2018 in 15:54 , Struktur ha scritto: With “Save all device puffs“ in Device Monitor, you get a file with 20 fields. It would be helpfull to add a field with “Profile“ ID (and/or Profile name). Where can I find "Save all device puffs" ? On device monitor does not exist. I have a DNA 250.
Gnagnom94 Posted December 15, 2018 Report Posted December 15, 2018 (edited) 13 ore fa, Wayneo ha scritto: DNA250C (Color screen) Unfortunately there's not this function for DNA 250 as you can see. Is it possible in some way, to use this functionality also for the standard DNA 250? Can you send the resulting output file? Edited December 15, 2018 by Gnagnom94
Wayneo Posted December 15, 2018 Report Posted December 15, 2018 2 hours ago, Gnagnom94 said: Unfortunately there's not this function for DNA 250 as you can see. You are correct, and why I specified 'color screen'. The color screen 250 saves those fields as a delimited csv file for each puff. AND with much more precision than the non color 250 using 'save all data'. 2 hours ago, Gnagnom94 said: Is it possible in some way, to use this functionality also for the standard DNA 250? Not that I'm aware of, although there is a 'Data Aquisition' option in the 'Research' tab but I haven't played with it.
