Hello there,
Can someone shed some light on the Tab Order: Automatic / Manual option?  The default is automatic.
What does it relate to and how is it used ?
Thanks,
JT
Hello
It is related on how the cursor moves in the theme screen. I mean , with automatic , the cursor starts from the upper left objects and ends to the down right one.
You can set it to manual and assign a numerical tab index to each object , if you need a different functionality.
Hope this helps.
  • Thanks 1
On Wednesday, May 30, 2018 at 3:42 AM, Frank65 said:
Hello
Hope this helps.
Thanks many.
I now see what it does. At this point I will stick to auto. For me the extra level of complexity is not needed.
 Am I wrong, it appears that it would be better used when starting a new screen or modifying a screen where all the fields were single layered?
JT
