Advice needed please
Bob R
Hi All,
First off I am Loving 'Replay' on both my 250C and 75C, Thank You Evolv you did a GREAT job.
What I would like to know is.... I used to vape in T/C using Ti wire, then I changed to 316L, I know using Replay it is set for power mode but if I want to use Ti wire again for some spaced coils do I need to upload the wire type profile from Escribe or does 'Replay' automatically sense wire type based on Ohms and Rise due to Temp/Power ratio?
Nope.
Nope, it's just using the rise as one, probably the most important parameter to model
Thanks, it's just I remember getting great flavour from Ti and I have loads of wire left but was a bit worried just using 'Watts' to set it up, I know in my diagnostics I have the Temp set to 410 deg F so that would take care of that aspect i suppose. Will give it a go later.
