Jesus13 Posted May 12, 2018 Report Posted May 12, 2018 When i first got the mod it wouldnt go above 130 amps so once i changed the soft cell cutoff to 3.5 it counts as two batteries right?it would hit at 167 but with a .2 build it won't I get ohms to high even at 155...it doesnt do that with a .1 build ?? How do I fix it on escribe
VapingBad Posted May 12, 2018 Report Posted May 12, 2018 No, the soft cell cut off is per cell not for all the cells together. It is hitting the limit because it is a 2 cell mod, there is nothing you can do in Escribe it is the max output voltage limit for 2 cells comping into effect.
Jesus13 Posted May 14, 2018 Author Report Posted May 14, 2018 Thankful and yea I finally realized that so I'll probably build a low ohm kanthal build to hit that wattage I want these ss coils are just not consistent on my vape calculator my build should be .1 but I get .2 or .25 on the mod
DNA_all_day Posted October 21, 2018 Report Posted October 21, 2018 On 5/12/2018 at 4:37 PM, VapingBad said: No, the soft cell cut off is per cell not for all the cells together. It is hitting the limit because it is a 2 cell mod, there is nothing you can do in Escribe it is the max output voltage limit for 2 cells comping into effect. Exactly
