Podunk Steam Posted May 6, 2018 Report Posted May 6, 2018 Over the course of a week or two I've been putting a DNA 60 into a Hana's V4 when I've had the time to tinker and I seem to have mounted the board up side down as the display is oriented the wrong way, it's showing the connection point to the glass through the mods window. To avoid lengthening the atomizer load wires and battery wires I'd much rather find a display with a much longer ribbon if possible. Would such a beast exist? This has already turned into an experience, the plastic clip to release the battery door was so well seated onto the brass part that makes electrical contact at the battery's negative its stem broke so I've milled a duplicate from brass. The screws were too short that came with the Cisco 510, this I found after turning a little height off the deck in order to have atomizers seat flat on top of the mod. And I didn't have a center drill so the intended 2.5mm threaded holes for the mounting of the 510 didn't align correctly so they got bored and the brass retention ring was used. My phone is not allowing me to upload pics to my picture host or I'd include some pictures. Any help with a long ribbon display would be much appreciated!
Podunk Steam Posted May 6, 2018 Author Report Posted May 6, 2018 Looks like another option offers itself so all the shenanigans with the display cables can be avoided, I'll just extend the recess in the housing for the display. Fingers crossed!
Podunk Steam Posted May 6, 2018 Author Report Posted May 6, 2018 Had to open the window a little but It's Alive!
Podunk Steam Posted May 7, 2018 Author Report Posted May 7, 2018 (edited) Tail of the tape. Broken latch copied from brass. Installed and looking crooked. Direction swap of the display. Pre-install. Modified Cisco 510. Escribage Done deal. Edited May 7, 2018 by Podunk Steam 1
Podunk Steam Posted October 10, 2018 Author Report Posted October 10, 2018 (edited) Stupid plastic parts anyway, maybe I'm done now. Slightly tricky little parts! Way better than original, easier opening and clicks shut as one would expect. Edited October 10, 2018 by Podunk Steam
