NMEones Posted April 27, 2018 Report Posted April 27, 2018 So the other day I decided to make my own theme and I have to say im extremely happy with the way it turned out... in my Last Puff Info page i added a field to say what the coil material is being used... Since I got the device, Ive only been using SS316L Fralien coils.... for some reason the device is saying that im using Titanium coils.. I just checked Escrbe and its saying the same thing? very confused about whats going on... I make my own coils so its not like someone sent me Titanium Coils as SS coils... Any insight would be most appreciated... thanks in advance!!
retird Posted April 27, 2018 Report Posted April 27, 2018 Check that you are selecting a profile that is using SS316L as the material....
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 28 minutes ago, retird said: Check that you are selecting a profile that is using SS316L as the material.... i was in wattage mode with replay and i originally had Watts chosen at material in escribe. it just recently switched over to titanium
retird Posted April 28, 2018 Report Posted April 28, 2018 It may have been changed when you made the theme....
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 I know I didn’t change it... I didn’t even touch escribe except to upload the theme. Should I just manually change the material and see if it sticks?
retird Posted April 28, 2018 Report Posted April 28, 2018 Change it to what you had set before.... The DNA does not automatically change materials in profiles for you....
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 I previously had it set to watts, left it how it was when I got it, didn’t want to mess with it since I didn’t know how it would effect anything,, I do know that I never changed it... I didn’t even go into escribe when I uploaded the theme and I had the field set to read only so I couldn’t change it on the mod. Once I uploaded the theme I went into the puff info page and it said watts, I took a puff and it switched to titanium. I honestly didn’t know that the chip didn’t change the material on it’s own (this is my first dna, that’s why I didn’t mess with escribe except to turn replay on) so now I’m a bit more baffled...
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 A little off topic... does your device keep resetting the time and date? I don’t notice when it happened, just eventually notice that it does.
retird Posted April 28, 2018 Report Posted April 28, 2018 18 minutes ago, NMEones said: A little off topic... does your device keep resetting the time and date? I don’t notice when it happened, just eventually notice that it does. When you open Device Monitor it updates the time from the computer...
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 I never opened that... at least to my knowledge I haven’t... but even so, wouldn’t it just update the correct time? The time is actually getting reset back to 12:00 and date 1/1/00
retird Posted April 28, 2018 Report Posted April 28, 2018 also the time can update when plugging in to the computer... IF you want could you post your self made theme file here so we can look-see....
NMEones Posted April 28, 2018 Author Report Posted April 28, 2018 When I get home I’ll check it out! I switched it back to watts before i left my house, when I get back in my car I’ll check to see if it’s still on watts
