Danielh1988 Posted February 4, 2018 Report Share Posted February 4, 2018 Hello I need some help diagnosing what went wrong with my effusion duo DNA 200 It randomly flashed check battery and completely shut down I don't have access to a computer for escribe can anyone help me figure out how to fix it Link to comment Share on other sites More sharing options...
Wayneo Posted February 4, 2018 Report Share Posted February 4, 2018 Your batteries could've run out of juice. Charge 'em up till you get to a PC and look at Device Monitor. You running the 18650's or Lipo? Link to comment Share on other sites More sharing options...
Danielh1988 Posted February 4, 2018 Author Report Share Posted February 4, 2018 I've tried both batteries once it did the check battery but when it happened it was the lipo battery and I put it on the charger for a couple hours and it still didn't boot up Link to comment Share on other sites More sharing options...
Danielh1988 Posted February 4, 2018 Author Report Share Posted February 4, 2018 On 2/4/2018 at 8:19 PM, Wayneo said: Your batteries could've run out of juice. Charge 'em up till you get to a PC and look at Device Monitor. You running the 18650's or Lipo? Expand I'm a strong believe in close mouth don't get fed by chance do you have a good 1300 mah lipo you could spare to test if it the battery Link to comment Share on other sites More sharing options...
Wayneo Posted February 5, 2018 Report Share Posted February 5, 2018 On 2/4/2018 at 8:43 PM, Danielh1988 said: .......... do you have a good 1300 mah lipo you could spare to test if it the battery Expand Sure do, YES! Whenever you wanna drop by my place in Canada I'll be ready. Link to comment Share on other sites More sharing options...
Wayneo Posted February 5, 2018 Report Share Posted February 5, 2018 On 2/4/2018 at 8:29 PM, Danielh1988 said: I've tried both batteries once it did the check battery but when it happened it was the lipo battery and I put it on the charger for a couple hours and it still didn't boot up Expand Not sure what you meant by 'both' there, but in order to check/test the 18650's, you'd need to also change the # of cells from 3 to 2, which must be done via escribe. Link to comment Share on other sites More sharing options...
Danielh1988 Posted February 5, 2018 Author Report Share Posted February 5, 2018 Didn't know you had to change the battery in escribe to use the sled but I think we figured out what was wrong with it Link to comment Share on other sites More sharing options...
awsum140 Posted February 5, 2018 Report Share Posted February 5, 2018 Right there, behind the milk. 2 Link to comment Share on other sites More sharing options...
Danielh1988 Posted February 5, 2018 Author Report Share Posted February 5, 2018 On 2/5/2018 at 2:04 PM, Wayneo said: Not sure what you meant by 'both' there, but in order to check/test the 18650's, you'd need to also change the # of cells from 3 to 2, which must be done via escribe. Expand I tried to use both the sled and the lipo also do you know if the 1300 mah maxamp 100c lipo will fit the efusion duo without issues? Link to comment Share on other sites More sharing options...
Wayneo Posted February 6, 2018 Report Share Posted February 6, 2018 Go look up the Turnigy 1300mAh size, and that's in mine. Compare the dimensions to the maxamp. Not a mm to spare anywhere. Link to comment Share on other sites More sharing options...
Danielh1988 Posted February 10, 2018 Author Report Share Posted February 10, 2018 Well I can at least use the maxamp to make sure it's my battery that's bad Link to comment Share on other sites More sharing options...
