Hello I need some help diagnosing what went wrong with my effusion duo DNA 200 It randomly flashed check battery and completely shut down I don't have access to a computer for escribe can anyone help me figure out how to fix it
23 minutes ago, Wayneo said:
Your batteries could've run out of juice. Charge 'em up till you get to a PC and look at Device Monitor. You running the 18650's or Lipo?
I'm a strong believe in close mouth don't get fed by chance do you have a good 1300 mah lipo you could spare to test if it the battery
17 hours ago, Danielh1988 said:
.......... do you have a good 1300 mah lipo you could spare to test if it the battery
Sure do, YES! Whenever you wanna drop by my place in Canada I'll be ready. :popcorn:
I've tried both batteries once it did the check battery but when it happened it was the lipo battery and I put it on the charger for a couple hours and it still didn't boot up
Not sure what you meant by 'both' there, but in order to check/test the 18650's, you'd need to also change the # of cells from 3 to 2, which must be done via escribe.
I tried to use both the sled and the lipo also do you know if the 1300 mah maxamp 100c lipo will fit the efusion duo without issues?
