Omega1397 Posted January 10, 2018 Report Posted January 10, 2018 Hey guys, I've been having some issues using TC with my Crown 3 coils on my therion and paranormal 166. I'm trying a profile I found by searching on the forums, that has the preheat power at 100W, temp at 530 F, and power at 80 W. My issues are: On my .25 coil, my hits start hard, and then they get cool about 1.5 seconds in, and then I see the screen "Temperature protected", resulting in a short, unsatisfying vape. For my 0.5 Ohm coil, the same thing happens but I get the error "ohms too high". I was wondering if anyone could help me out. It would be very much appreciated!
Omega1397 Posted January 10, 2018 Author Report Posted January 10, 2018 (edited) Woah wtf, both of my mods show 0 battery and give me a "check battery" error. The last thing I did was I restored my theme defaults, then I made a TC profile with the (Uwell Crown 3 SS) csv. When I try going into device manager I get the "Device is already in use" error Edited January 10, 2018 by Omega1397
Sam Lowry Posted January 11, 2018 Report Posted January 11, 2018 You may have used such a default setting that it's now looking for the default 3 battery setup. Try to maybe upload a profile made for that mod and see if that fixes anything. As for the tank TC trouble, what material are your coils made out of?
giz_60 Posted January 11, 2018 Report Posted January 11, 2018 14 hours ago, Omega1397 said: Hey guys, I've been having some issues using TC with my Crown 3 coils on my therion and paranormal 166. I'm trying a profile I found by searching on the forums, that has the preheat power at 100W, temp at 530 F, and power at 80 W. My issues are: On my .25 coil, my hits start hard, and then they get cool about 1.5 seconds in, and then I see the screen "Temperature protected", resulting in a short, unsatisfying vape. For my 0.5 Ohm coil, the same thing happens but I get the error "ohms too high". I was wondering if anyone could help me out. It would be very much appreciated! According to the info provided by Uwell on their coils, it seems that the SS coils you are trying to use for TC are better suited for wattage & the Ni200 coils for TC.... Uwell crown replacement coils use revolutionary food grade stainless steel. Standard 0.25 and 0.5 coils are made of SUS316 D-Grade Stainless Steel Heating Wire and use 100% Japanese organic cotton. Temperature Control coils are made with 0.2 Ni200 Nickel wire. 0.15 ohm (Ni200 – Nickel) 0.25 ohm (80 – 120W) 0.5 ohm (30 – 80W) 1
Omega1397 Posted January 11, 2018 Author Report Posted January 11, 2018 Oh wow. So I should be using Ni200 for the material setting for my TC? Or should I use a special .csv? I really appreciate it! By the way, i'm talking about the Crown 3 coils here.
giz_60 Posted January 11, 2018 Report Posted January 11, 2018 (edited) You can't use Ni200 material settings unless you are using the Ni200 coils...The info I previously posted was taken from Uwell's info on the Crown 3 coils & according to that info, the .25 & .5 ohm coils are better suited for wattage usage, not TC.... Edit:. Here is a response about a question of those coils found on another forum.... SS Coils on Uwell Crown have nickel legs, so they're to be used only on power mode because TC wouldn't read it correctly Edited January 11, 2018 by giz_60
