I just got a Boxer DNA75C Squonk that takes (1) 20700/21700 battery. I purchased 2 Keeppower 20700 batts from Illumn. They get good ratings from Mooch so I went with them. When I charge them on my Xtar VP2, they charge to 4.20 and the mod reads them at 98%. That’s fine. It’s when use the mod, the battery levels are all over the place. They go from 98 to 84 then up to 86. When they get below 60%, that’s when the battery meter gets really wonky. It will drop to 34% and then 13%, then up to 30%. It’s quite frustrating. All firmware is up to date. I vape at 50 watts on a .3 single coil setup. I purposely paid a premium to get a DNA chip and I feel like it is very problematic. Also, the clock always goes back to 12:00 when I change the battery but my wattage settings stay where they were before the battery swap. Hopefully this is a firmware issue that will be addressed. Working outside all day without being able to charge, is making this mod a bit useless.
Here is the battery specs:
PRODUCT DETAILS
20700 KeepPower 3000mAh High Discharge Flat Top
Molicel INR-20700A Internal Cell
Specifications:
Minimum Capacity: 2800mAh
Typical Capacity: 3000 mAh
Nominal Voltage: 3.7V
Discharge End Voltage: 2.5V
Max Continuous Charging Current: 3A
Max. Continuous Discharging Current: 20A (KP rating) 30A (Mooch rating)
