Is it possible create a theme that allows one to change the battery CVS on the mod? For example, if the user is using battery X and swaps out for battery Y, can this be changed on the mod or must the device be connected to Escribe?
This pertains to the 75C. I know this is not possible on previous boards.
Regarding batteries; I'm a little confused with the latest versions of escribe. There are max settings on the battery tab and on the electrical tab. Which takes precedence? On the battery tab, shouldn't these max settings be saved and loaded with the battery CSV files? That way, these setting are automatically loaded when a new CSV is loaded.
Battery tab max setting is for input and max setting on the electrical tab is for output.  I don't recall there being a theme function to change the battery csv from the device theme itself.
Well, I'm not too clear on that either. So on the battery tab, those settings are for input of power from the battery to the coil and on the electrical tab, that is for charging of the battery?
