joeygregory Posted November 4, 2017 Report Share Posted November 4, 2017 I have recently bought the therion 75c BF the little light under the power button or the fire button I mean does not go out I went into evolve and disabled it it's still on? I even set a light and a different color that changed so I updated it again with no light and it went back to green? Everybody else with this mod their light goes off until they hit the fire button mine stays green the whole time the mod is on or the screen is lit and when I hit fire then it turns colors any suggestions on how to fix this it's very annoying? If I can't find a quick fix it will be returnedo Link to comment Share on other sites More sharing options...
retird Posted November 4, 2017 Report Share Posted November 4, 2017 Does the device have the original Theme installed as on all new Therion's and is your device new? Can you post the theme file so we can look at it? 1 Link to comment Share on other sites More sharing options...
LT Rogers Posted November 4, 2017 Report Share Posted November 4, 2017 I helped Joeygregory install the theme. The light was on before I loaded the theme, I went into theme Designer and turned off the light but it still stays on. The Original theme is listed under my name, I Attached it here CARBON_W_TNSMASK.ecigtheme 1 Link to comment Share on other sites More sharing options...
retird Posted November 4, 2017 Report Share Posted November 4, 2017 Save your theme and then load this one and see what you get? Was this a new device with the original theme installed when you got it? Evolv Default Theme.ecigtheme 1 Link to comment Share on other sites More sharing options...
joeygregory Posted November 5, 2017 Author Report Share Posted November 5, 2017 Yes this is a brand new device when I received it and took it out of the box put the battery in powered it on the default theme was on there and the green light stay lit the whole time my device screen was on I thought it was part of the device until Jeff who answered the first question who installed the theme for me got the same device and advised me that his light went off and so did another friend of mine so I'm wondering why my device came like this and what is going on I don't want problems later on down the road with it this could be the start of something terrible it's only a few days old so I can return it if I can troubleshoot the problem that's probably what I'm going to have to do Link to comment Share on other sites More sharing options...
joeygregory Posted November 5, 2017 Author Report Share Posted November 5, 2017 When Jeff has time I will have him try this link you sent me I appreciate it because I have no way of doing themes my Windows computer is not reading the device for some reason it's my daughter's computer and God knows what she did to it so I'm scared to even plug it into that LOL Link to comment Share on other sites More sharing options...
retird Posted November 5, 2017 Report Share Posted November 5, 2017 OK.... let us know what you get when you try the theme.....if it still has the issue you probably should return it for replacement to the vendor or start a ticket with Evolv for them to guide you and/or repair it.... Evolv's link to tech support..... https://helpdesk.evolvapor.com/index.php?a=add&category=1 1 Link to comment Share on other sites More sharing options...
joeygregory Posted November 5, 2017 Author Report Share Posted November 5, 2017 I talked to Jeff he informed me that he did this yesterday he installed the theme you included and then the light did not go out then he reinstalled the other theme and the light still. Did not go out? It makes no sense it turns colors when you fire it and when it's charging through USB the red light blinks on and off? I have no clue what's going on why it's doing this Link to comment Share on other sites More sharing options...
retird Posted November 5, 2017 Report Share Posted November 5, 2017 Strange thst his light now won't go out either...... You might also try installing this Evolv default .ecig file and see if the light goes out...(save your .ecig file first)..... Default Evolv ecig file.ecig Link to comment Share on other sites More sharing options...
LT Rogers Posted November 6, 2017 Report Share Posted November 6, 2017 23 hours ago, retird said: Strange thst his light now won't go out either...... You might also try installing this Evolv default .ecig file and see if the light goes out...(save your .ecig file first)..... Default Evolv ecig file.ecig My light goes out. I don't have the issue on my device using the same themes. On his device I did as you suggested with the reset and the light doesn't go out. Now the light isn't bright but you can see it in a dark room. Joey's device came with the light on straight out of the box before it was hooked up to any computer or escribe for that matter. I'm at a total loss as of now. Link to comment Share on other sites More sharing options...
