Hi guys, I have just received a couple of brand new Samsung Q30 batteries, along with a new Therion 75C, and I'd like to upload on the device the correct .csv profile.
At the moment the batteries have been charged only one time with an external charger at 0.5 mAh (took me something like 7 hours and half to completely charge them).
Do you have a .csv profile suitable for a dna 75c, for 2x Samsung Q30 batteries? Also, which "cell soft cut off", "capacity Wh" and "nominal voltage" values I have to apply?
I have found a .csv profile in another thread, over there, but it was intended for a Therion 166 and I don't know if there is something different to consider, given that my Therion is actually a 75.
Thanks a lot!
Alex
  • 3 months later...
You can use that one
I assume he meant this thread?
I also assume the two mods being in series and parallel doesn't matter when it comes to the discharge profile?
Thanks for the prompt reply!
@PepeSilvia Easy answer ......  Yes to everything.
It's a simple 2 column csv showing Battery Charge %, and the voltage. Only affecting the display gauge.
Depending on your vaping characteristics you'll get different usage results in real life. In general, you'll get better results with a serial board
