danny8200 Posted September 30, 2017 Report Posted September 30, 2017 Using a Lost Vape Triade with SS316L profile and coils on a Kylin RTA. I unscrew the tank and screw it back on, I get the New Coils? Message and select Yes. I get the warm vape that I am trying to achieve at 0.16 ohms. I try again about 10 minutes later and the ohms go back to 0.15 and the vape is way too cool. I've tried adjusting many settings in EsCribe with no luck. Hopefully there is nothing wrong with my mod. I want to say its pure user error and wanted to double check with you guys. It seems to work just fine when I lock the ohms at 0.16 but I've read that it's not advised to lock ohms. Any takes?
VapingBad Posted October 1, 2017 Report Posted October 1, 2017 You just have a slightly unstable connection some, SS has such a small resistance change with temp it doesn't take much to affect temp limiting. I would start by checking the coil is tightened down well and clean the 510. 1
