blackhat Posted September 22, 2017 Report Share Posted September 22, 2017 I have an RDA that I use on my DNA 250, .13-.14 OHMS, the DNA75 can only fire .15 or HIGHER in TC according to the box, what are the dangers if any? Or should I just toss a new build on? I wanted to give this a 'try' for squonking. edit: its working but is this considered safe I guess is the real question, lmao.. Link to comment Share on other sites More sharing options...
VapingBad Posted September 22, 2017 Report Share Posted September 22, 2017 I have been using 0.05 ohm Ni with 200, 75, 250, 167 & 75C, my favourite build without any issues. To get the exact figures you need to check the graphs in the spec sheet, but I am sure 0.13 is comfortably within the range. https://www.evolvapor.com/products/dna75 1 Link to comment Share on other sites More sharing options...
James Posted September 22, 2017 Report Share Posted September 22, 2017 The ranges are for 75W operation. Outside the ranges, there are cases where you may not get the full 75W at all times, but it should still operate fine. Minimum resistances are due to the current limit: Pmax=Imax^2*R Maximum resistances are due to the voltage limit. Pmax=Vmax^2/R The data sheet's temperature-sensing coil graphs are for Nickel. For Stainless, the range is closer to the Kanthal graph. Link to comment Share on other sites More sharing options...
