Vapekanuck Posted September 9, 2017 Report Posted September 9, 2017 (edited) I could use some assistance, I am going to be installing a DNA 75 board into a 3D printed case, batteries will be LG HG2 DUAL PARALLEL. Now this is the part that I need help with. Once I have to mod complete how do I set up the battery with escribe so I can get the best performance, please and thanks Edited September 9, 2017 by Vapekanuck
Vapekanuck Posted September 12, 2017 Author Report Posted September 12, 2017 Do i set this up in escribe as 2 cells?. which are in parallel
giz_60 Posted September 12, 2017 Report Posted September 12, 2017 There is no option for the number of cells on the 75...
Vapekanuck Posted September 12, 2017 Author Report Posted September 12, 2017 Ok thanks, Is there any kind of setting I need to do? Only vaping in wattage mode around 45watts with .6ohm dual coil rda.
giz_60 Posted September 12, 2017 Report Posted September 12, 2017 Most of the Evolv defaults should work fine... you might want to load a .csv file for those batteries to improve the accuracy of the battery level indicator on the device... LG_HG2 (2)_18650_3000 mah.csv
fuligin Posted September 12, 2017 Report Posted September 12, 2017 4 hours ago, giz_60 said: Most of the Evolv defaults should work fine... you might want to load a .csv file for those batteries to improve the accuracy of the battery level indicator on the device... LG_HG2 (2)_18650_3000 mah.csv would this file work for single battery ?
giz_60 Posted September 12, 2017 Report Posted September 12, 2017 59 minutes ago, fuligin said: would this file work for single battery ? LG_HG2 (1)_18650_3000 mah.csv 2
fuligin Posted September 12, 2017 Report Posted September 12, 2017 Thank you...thank you!! loading this up now
