Metoo Posted September 7, 2017 Report Posted September 7, 2017 The up button on this new board automatically increases the power until it goes off. The button seems to work as it should and as the down button. This happens without the exterior button in place. Is there any cause for this other than the button being defective? Thanks.
Wayneo Posted September 7, 2017 Report Posted September 7, 2017 Have you taken the button apart, cleaned or look at the insides, then put it back together? The light green actuator is held in place by the outer metal frame. You can lift it (metal tab only) slowly by one edge, and it'll come off at like a 45 degree angle, then just lift the rubber part up. Check and clean, put it back together. 1
Metoo Posted September 7, 2017 Author Report Posted September 7, 2017 Thanks for your reply. No joy . No change. Any other suggestions?
Wayneo Posted September 8, 2017 Report Posted September 8, 2017 (edited) After working with @giz_60, if it's still no joy, (no vendor or mfgr warranty) open a ticket with Evolv. EVOLV HELP DESK - https://helpdesk.evolvapor.com/?a=add Edited September 8, 2017 by Wayneo
Metoo Posted September 8, 2017 Author Report Posted September 8, 2017 21 hours ago, giz_60 said: What mod is that? Built with an Alpinetech box.
