Theplasticbling Posted August 27, 2017 Report Share Posted August 27, 2017 I'm using a jac vapour series b dna 75. I'm using a single sony vtc6 3000mah battery. The cell soft cutoff is at 2.75v. I let the battery drop all the way and checked it with device monitor, and it goes all the way down to almost 3.0 volts. I feel like this is too low. Is this normal? Thanks. Link to comment Share on other sites More sharing options...
VapingBad Posted August 28, 2017 Report Share Posted August 28, 2017 Yes, probably, it would vary depending on the age of eh battery and the power you vape at, but 3 V is OK, 2.5 V is the min most batteries are speced for. If you prefer it to be a bit higher raise the cut off by all means. Link to comment Share on other sites More sharing options...
