well all was working ok and then it just stopped firing ,it might pop up the check atty once after a reset for a split second but after that nothing,the up and down buttons work but not the fire any help would be nice
Hook it up to EScribe and open Device Monitor on the bottom it shows what buttons are pressed, you do need to press for a couple of seconds before it updates. If it is showing as pressed then it a board issue, if it is not it could be dirt in the switch and you could un clip the top of the switch and clean the inside and underside (concave) of the metal disk.
This is a 40 switch, but they are almost the same.
button
ok did the hard wire test and nothing
did the button clean and nothing
works when simulate fire in escribe
did service pack rollback and reinstalled both and still nothing
sorry but I think something is not right somewhere
Edited by decoy
