turnthedamnwattsup Posted July 4, 2017 Report Posted July 4, 2017 Had this awesome mod for about a month and was wondering why the battery life is not as good as my Therion DNA75. Using the same RDA with the exact same build (0.25Ohms) in TC at 75 watts on the same batteries (tried LG HG2 and Sony VTC6), pre hear at 75Watts as well on both mods. i noticed that the Therion DNA75 does not drain the batteries as fast with the same daily use. The Drone's DNA board is a 250 throttled down to a 166 if Im not wrong. Appreciate any thoughts on how I can solve this issue? Thanks
giz_60 Posted July 4, 2017 Report Posted July 4, 2017 If you are gauging your battery usage by the indicator on the device's screen, it's possible that you don't have the battery settings figured correctly on the device. Can you post a screen shot of the 'Mod' tab in Escribe?
Wayneo Posted July 4, 2017 Report Posted July 4, 2017 Have you loaded the same battery curve, and set the same 'cell soft cutoff' on both? If you charge on an external charger, what resting voltage are they at when put on the charger?
turnthedamnwattsup Posted July 5, 2017 Author Report Posted July 5, 2017 (edited) Thanks for replying @Wayneo and @giz_60 I have attached the screenshots of the 75 and 250. Indeed the values are not the same and also the battery curve. Changed the cell soft cutoff to be the same on both. Also loaded the same battery curve. I'll test and see if the 250 is ok. Thanks for the help Edited July 5, 2017 by turnthedamnwattsup
Wayneo Posted July 5, 2017 Report Posted July 5, 2017 Your 75 appears to give you better battery life (based on the screen) because it has much simpler battery management/display On you drone you have it set for ~13Wh, so the display will be off. Simple fix. Set your Wh's to say 22. When you get a check battery or you notice a weak vape, plug into escribe. Look at the Wh's it says you should have. Subtract that value (Around 3-6) from your 22. Your display will then be accurate. PS Your Therion 'mod resistance' has not been set.
giz_60 Posted July 5, 2017 Report Posted July 5, 2017 Here are .csv files for both types of the cells you use...the Wh's are stated in the file name...These .csv files were generated by running the 'Battery Analyzer' in Escribe... LG_HG2 (2)_18650_3000 mah_18.75 Wh.csv Sony_VTC6 (2)_18650_3000 mah_19.96 Wh.csv
turnthedamnwattsup Posted July 6, 2017 Author Report Posted July 6, 2017 Thank you both! Great to own DNA devices! @Wayneo Ive set the Mod resistance back to normal. Also the Wh to @giz_60 csv file - I use both batts so I guess 19.33 is the average. Lets see how it goes. You guys are awesome.
