B- and GND
67exec
putting a dna 60 in a vapor flask clone, and I'm sure that I can just hook the B- and the GND together, but checking first.  The daughter board was broken in the device when I got it, so it had to go by the wayside. Next question is, should I run a jumper from B- to GND, or run 2 separate wires from the solder tab on the 510? This mod uses the case as the B-
Thanks in advance
