VT250 Help
Visara
I have a VT250 by HCigar. I'm using three LGHG2 batteries in it.
The problem is the battery meter shows the batteries are draining way too fast. Faster than they actually are.
They'll be showing 80% battery life and I can hit the device once and it'll show they're down to 77%. This happens every time. Eventually, they'll be showing 0% battery life, but I am still able to use the device for at least two more hours.
So I'm getting the correct amount of battery life, but for some reason, the battery meter shows they're draining faster than they actually are.
I went into Escribe and messed around with a whole bunch of different things, but nothing fixed it. It's driving me crazy.
I've tried using 25Rs and VTC5s. The device still shows much less battery life than there actually is.
Does anyone know how to make the batter meter read correctly? I'd really appreciate any help.
Your battery capacity is probably set too low, there is no harm in adjusting it by trial and error, 22-23 Wh is probably close, but there are probably profiles with the Wh noted for those cells on here that would be even more accurate,  If you can see the mod tab go to options - UI and set it to Advanced.
