3Vis_N Posted May 17, 2017 Report Posted May 17, 2017 Hi, I'm new on the forum and I have just receveid a vtbox DNA 250 after my dear wismec 2/3. I'm also new with escribe, but after a lot of videos I'm now a bit pratical of it and I want to ask you if you can give me some advices of settings. I use the ss316l and kantal a1, what are your advices? Can you attach an image of your configuration? Also with other type of wire, thanks.
ScaryMonkeyMan Posted May 17, 2017 Report Posted May 17, 2017 Are you running the ss316L in temp control, and what gauge/wrap/ohm are you using? Personally I will switch in between temp and power on my coils. I get a comfortable vape at 100w in wattage mode so I will set the wattage there and set the temp to about 470℉. Haven't really needed to use the preheat punch because the wattage setting ramps it up quick enough.
