antyac2108 Posted July 9, 2015 Author Report Posted July 9, 2015 What is the highest tempatures the board can handle from soldering?
VapingBad Posted July 9, 2015 Report Posted July 9, 2015 Probably more the time the iron is on the joint than out and out temp, use a good powerful temp controlled iron and set the temp to what works well with the solder and wire you are using.
antyac2108 Posted July 9, 2015 Author Report Posted July 9, 2015 I have a temp control iron but it's old and I'm using 60/40 wire.I just don't want to hurt this board and I'm using 14 gauge wire so I have to hold it on there too get it to flow
VapingBad Posted July 9, 2015 Report Posted July 9, 2015 Tin the wire first and get it hot/wet just above the pad then push it on to the pad with the iron and feed a little fresh solder and you can get it on quickly.
antyac2108 Posted July 9, 2015 Author Report Posted July 9, 2015 I'll post pics when done I have a 1590A with a shapeway front cover that is being delivered today I'm going to build it tonight
lolerwaffles Posted July 11, 2015 Report Posted July 11, 2015 I always solder temperature sensitive items with as chunky of a tip as will fit in the space I am soldering, and my iron all the way up to 480. Hot and fast, so the solder points heat up fast instead of the rest of the item.
