Hi. I built my first DNA200 mod earlier today. When I initially connected it to escribe all 3 cells where showing identical voltage values.
After a few tests, one of which involved a shorted atomizer, the cells are now out of balance, and don't seem to be correcting themselves.
Cell 1 has just been gradually decreasing to the point where it's now under 1 volt.
Any suggestions ?
After 1 1/2 hours, cell 1 -3.5, cell 2 -3.5 cell 3 -3.36. Strange that cell 3 never goes above 3.36. I think my solder is good on balance charger, not sure what could be going on other than cell 3 is bad? I did accidentally let it charge without changing it to lifepo4 in escribe for a short time.
Can you set up a graph of all three cell voltages in device monitor, then take a couple puffs and post the screenshot? We'll be able to see if it is a bad cell and if so, which cell.
That all looks pretty reasonable. There's basically zero capacity difference in a LiFePO4 pack between 3.6 and 3.35 volts, so if it stays nicely balanced throughout the rest of the range (3.30-3.30-3.29 is fine) then I wouldn't worry about it.
so im having an issue with something causing the battery to not be balanced. Ive checked the tap connector and everything is solder nice and solid and tried two different lipos by two different companies and Escribe always shows cell 1 at 0 volts, cell 2 at 4.84 and cell 3 at 3.88 im so confused by this
Ah, this is an easy one. You have way too much solder on the top-most tap connector pin (GND), it is shorting out the cell one sense line. Remove the extra solder and you should be good.
John,
I pm'd you about my issue too. From the previous pic, it looks like one of my resistors got knocked off but not completely. I'm not sure if I can solder something that small back on.
KFC can you post a higher resolution picture of the area around the USB ports and the balancer? It has to be one of the outside two resistors in that set of four, or the balancer lead.
i dont know if this matters but when hooked up to the usb the screen stays lit like any normal dna but off the usb i have to hold the fire button for the screen to stay on or it will just turn off i was thinking its part of the battery being misread but idk just thought i should add as much info as possible about whats going on
If you have a voltmeter, what voltage do you get when reading between the solder joints of the 1 and Gnd tap connections? Then what voltage do you get between the far side of the resistors closest to the side? Everything looks pretty textbook except the GND tap solder joint, but that doesn't look so egregious as to be making no contact.
What's your serial number? I can see if the production data for your board shows anything unusual, but the board looks right to me.
