AllenH Posted August 2, 2015 Author Report Posted August 2, 2015 Hi Everyone!How is everyone's room temp reading? Mine is off by 10 degrees F. Any thoughts?Thanks!!-Allen
VapingBad Posted August 2, 2015 Report Posted August 2, 2015 Mine is always high, but to be expected in a almost sealed xox my hand heats every now and again, but I don't have an accurate thermometer here to say how high.
AllenH Posted August 2, 2015 Author Report Posted August 2, 2015 Hmm- I realize I'm looking at the device monitor info, and that my device is plugged in- perhaps the charging circuitry raises the temp by 10 degrees F? Might be conceivable! Especially in a closed box!
John Posted August 2, 2015 Report Posted August 2, 2015 You need to run case analyzer and get your thermal coefficients for it to be right. Once you have done that it should be pretty bang on.
AllenH Posted August 2, 2015 Author Report Posted August 2, 2015 AH - ok, John. I'm gonna drop you a quick PM about this box. I'll keep it short. THANK YOU!!
AllenH Posted August 2, 2015 Author Report Posted August 2, 2015 You know, John has a very good point here! I just checked out the case-analyzer portion of escribe, and the Delta-T for charging on USB is 10 degrees... that's right on the money for our house temp at the moment (91-10 = 81).So, I bet it's correct!!
VapingBad Posted August 2, 2015 Report Posted August 2, 2015 John said: You need to run case analyzer and get your thermal coefficients for it to be right. Once you have done that it should be pretty bang on. Expand I have so many computers in here I struggle to get the temp below 28 C at this time of year and both time I have run case analyser it spends the first hour waiting for the temperature to drop, I got quite different results each time, but the were different ambient and doff versions of escribe.
John Posted August 2, 2015 Report Posted August 2, 2015 Those aren't that different, really. Either should get you within a few degrees of correct.
VapingBad Posted August 2, 2015 Report Posted August 2, 2015 I was meaning the cooling and heating time constants were different, I am not worried about and just posted as the topic came up.
