LTG Posted August 2, 2015 Author Report Posted August 2, 2015 I'm no electronics expert but I have read many of the users posts for years in other forums and have always given helpful advise. Would it be possible to run any other type of connection and possibly run two screens off a single DNA 200? I know enough to get myself in trouble, but my knowledge on electronics and what problems I could run into will get me into trouble so I'm asking. Please put this in the proper place if I am asking the wrong questions or more than one in a single post. With a switch(a/b) could it fire a second 510 connection? If two 510's were attached and only one was being used would it need a switch or would it tell me to check atty? Could the screen and all tac buttons be run on the board, and a second set of screen, fire, mom/tac switches be run a length of 1-2 meters(5-7feet)? How large would the cable need to be? If this isn't possible could you run all the necessary wires(+/-,balance connector) 1-2meters? How large would the wire need to be(if it's a case where the longer they run the larger wire is needed is there a table or formula I could use?) I want to thank everyone that's apart of this discussion, and i hope this isn't a laundry list of new comer dumb questions. If so that's a bummer hi! I know some of these questions are already answered n if that's the case it can be left alone, but if not please help I'm usually try first and if didn't work, keep going. In this case I want to know before I do some work that can't be undone. I'm thinking a 2liter squonk/bottom feeder with the power to keep it going. Not really, but I'd take it camping! Thanks Rob J LTG
Darklyspectre Posted August 3, 2015 Report Posted August 3, 2015 I am not the greatest in electronics but The dual atomizer thing should be possible. I don't THINK you really need a switch but the 510 not being used cannot have any build on it. The switch would fix that I think. But then again this switch needs to be able to handle up to 55 amps. fire,+,- is no issue. I had soldered on my own buttons and the onboard switches still work even with soldered buttons on the board. The 510 and buttons should be good to go. The screen I don't think can be done. I looked around and I cant find anything that would split one ZIF output into two. (no point since it would show the same thing on both anyway)I don't think length is really that much of a issue with the + and - on the battery. one meter isn't a stupidly long length for current to travel. Same with the balancer too I think.
KTMRider Posted August 3, 2015 Report Posted August 3, 2015 The chip would have to be close to the 510 or your resistance would include a long wire run.
LTG Posted August 3, 2015 Author Report Posted August 3, 2015 So if one was to fire the 510a calling it the one closest to the chip and 510b being far away. using a 12 g pair wouldn't create anything troubling would it?
LTG Posted August 3, 2015 Author Report Posted August 3, 2015 I went so far as to label the 510' and left little or no explanation. could one chip be used to create a home style APV that has a build station with a 510a that meters a build and 510b in a very comfortable to hold hand piece with just a fire button and up/down. I guess the screen could be set up on the build box and it could be adjusted to flavor. If this was done how could you do it so it does't void any protection that evolv has?
John Posted August 3, 2015 Report Posted August 3, 2015 The screen would be a bit of a trick: it talks both ways to a certain degree, so if two screens were responding, the processor would probably get confused. Two outputs wouldn't cause much hardship. If both had atomizers attached and they weren't matched, then temperature control wouldn't work, but otherwise that half of the plan would work fine. As long as the wire lengths match, you can use a mod resistance setting to compensate for the extra wire.
