Tjroehr Posted September 4, 2015 Author Report Posted September 4, 2015 I'm trying to update my dna 200 board and It crashes before it even starts. This is what happens, I press the update firmware button and it says please wait, on the loading bar. Then it says "please wait (not responding). Then I get a Microsoft .net framework box that says... Unhandled exception has occurred in your application. If you click continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately... So after this if I press quit, escribe quits. If I press continue escribe stays open but the firmware doesn't reload onto the board. The board is crashed and doesn't work (it still displays info on screen but I cant fire it) At this point I have to restart the board to be able to use it. This is what the details tab of the .net framework says...See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text **************F.z: Exception of type 'F.z' was thrown. at F.XS.j(Stream , Byte[] , Int32 , Int32 , Func`2 , Func`2 ) at F.XS.k(Stream , Byte[] , Int32 , Int32 , Func`2 ) at F.XS.y(Stream , UInt16 , UInt16 ) at F.XS.W(Stream , UInt16 , Boolean ) at F.XS.p(Stream , Boolean ) at E.em.kw.g(Stream ) at F.Xm.v(Boolean& , Object , Func`2 , Func`2 , Boolean ) at E.em.kw.K(xj , Action ) at b.BO.OnShown(EventArgs ) at System.Windows.Forms.Form.CallShownEvent() at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() ************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.96.0 built by: NETFXREL2STAGE CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll----------------------------------------DEScribe Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/EScribe.exe----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------DimensionEngineering.Common.Windows Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DimensionEngineering.Common.Windows.DLL----------------------------------------DimensionEngineering.Common Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DimensionEngineering.Common.DLL----------------------------------------DEScribe.Core Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DEScribe.Core.DLL----------------------------------------DimensionEngineering.PluginApi Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DimensionEngineering.PluginApi.DLL----------------------------------------DEScribe.Branding Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DEScribe.Branding.DLL----------------------------------------DimensionEngineering Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DimensionEngineering.DLL----------------------------------------System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll----------------------------------------System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------DEScribe.PluginApi Assembly Version: 1.4.0.0 Win32 Version: 1.4.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/DEScribe.PluginApi.DLL----------------------------------------System.Security Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll----------------------------------------IllusoryStudios.OpenSsl Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/*%*/AppData/Roaming/Evolv/EScribe/IllusoryStudios.OpenSsl.DLL----------------------------------------SecondLanguage Assembly Version: 1.0.2.1 Win32 Version: 1.0.2.1 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/SecondLanguage.DLL----------------------------------------Mono.Addins Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/Mono.Addins.DLL----------------------------------------Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------IllusoryStudios.Math Assembly Version: 1.1.0.0 Win32 Version: 1.1.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/IllusoryStudios.Math.DLL----------------------------------------EquationParser Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/*%*/AppData/Roaming/Evolv/EScribe/EquationParser.DLL----------------------------------------HidSharp Assembly Version: 1.8.1.0 Win32 Version: 1.8.1.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/HidSharp.DLL----------------------------------------NBit Assembly Version: 1.2.1.0 Win32 Version: 1.2.1.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/NBit.DLL----------------------------------------SaberUpload Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/SaberUpload.DLL----------------------------------------ICSharpCode.SharpZipLib Assembly Version: 0.86.0.518 Win32 Version: 0.86.0.518 CodeBase: file:///C:/Users/*%20*/AppData/Roaming/Evolv/EScribe/ICSharpCode.SharpZipLib.DLL---------------------------------------- ************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled. For example: <configuration> <system.windows.forms jitDebugging="true" /></configuration> When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
blueridgedog Posted September 9, 2015 Report Posted September 9, 2015 Do have access to another computer? I quick way to determine if it is PC setup or chip is to install escribe on a clean, non-development, system and try the manual firmware update.
