morpheusneo Posted September 26, 2015 Author Report Posted September 26, 2015 I just got a Hana Modz V200 yesterday. I'm loving it and it looks great. I'm just having a couple issues with it. First of all it let's me know that there are unbalanced cells. When checking them in eScribe cell 2 is at 4.05 or so when the others are at 4.2. I hit the forum here and saw where people said to change the display to show the voltage of the cells while charging. I did this in eScribe and uploaded the setting to the mod but the screen doesn't change when charging, it still shows ohms, voltage and temperature. I have it plugged into the computer running the battery reset through eScribe now. I'm just wondering why the changes aren't taking place after uploading and what should be done to fix the unbalanced cells if eScribe doesn't correct it. Thanks!
PROT Posted September 26, 2015 Report Posted September 26, 2015 the charging brightness is set to 0 by default....i set mine to 40 % and i see the charging screen...is that your problem maybe
morpheusneo Posted September 26, 2015 Author Report Posted September 26, 2015 That very well could be the problem with the display changing when charging. I'll have to check it out as soon as I get back home. I hope so, then I'll just have to worry about fixing the low cell.
morpheusneo Posted September 27, 2015 Author Report Posted September 27, 2015 Thank you Prot! I feel so silly, that was the problem with the not being able to see the charging screen. It was set to 0. I feel like such a noob. Now I just need to get the cells evened out. Cells 1 and 3 are now at 4.2 and cell 2 at 4.1 so it's much closer. I don't know how close they should be. I know I read it on here somewhere. I will have to do some research.
Legros Posted September 27, 2015 Report Posted September 27, 2015 Let it charge over night to balance the cell It take long it work by discharging the high cell until they are in balance
