Vapor shark dna 200 only charging to 98%?
Max charge cycles will charge to 4.1 V per cell probably doubling the life of your battery
Max puff will charge to 4.2 V per cell using the full capacity of your battery
I mainly use max charge cycles and it has be great, but I don't display the %.  I wouldn't worry about 1 % if the cells are all showing as 4.2 V in device monitor, you could probably get rid of it by reducing the battery Wh a little or if it's new it may take a few cycles to catch up.
I don't think it is much, there is a thread where I requested to be able to set the charge voltage somewhere here that has some more detail.
ETA
https://forum.evolvapor.com/topic/66189-topic/
About 80% capacity for double the battery life
Batt Uni says 86% http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
