Pro_Vapes Posted November 2, 2015 Author Report Share Posted November 2, 2015 I'm running a dual Ti01 .5mm, 3mm ID, 8wraps @ .17 ohm. I tried to load the SSV .5mm Ti01 csv and I get this message.... This my 1st DNA200 and my first csv... Hcigar VT200. Any idea what I'm doing wrong? Link to comment Share on other sites More sharing options...
lexalove Posted November 2, 2015 Report Share Posted November 2, 2015 I would say you are not doing anything wrong, the problem is the csv file you are trying to load.I don't know who or what SSV are but the TFR relates only to the material and not the size of the coil. Try downloading the csv for Ti from http://www.steam-engine.org/wirewiz.asp and see if that solves your issue. Link to comment Share on other sites More sharing options...
Pro_Vapes Posted November 3, 2015 Author Report Share Posted November 3, 2015 When creating a csv file on steam engine ado I use single or parallel for a dual coil setup? Link to comment Share on other sites More sharing options...
Dampmaskin Posted November 3, 2015 Report Share Posted November 3, 2015 As long as you don't mix materials, the only setting in the Wire Wizard that is relevant to the temperature profile, is your choice of material. Link to comment Share on other sites More sharing options...
Pro_Vapes Posted November 3, 2015 Author Report Share Posted November 3, 2015 OK, thanks... I'll give it another shot. Link to comment Share on other sites More sharing options...
