Rip Posted November 4, 2015 Author Report Posted November 4, 2015 Is the measurements usually given for a lipo with or without the wrap? Im trying to find the right lipo. If the measurement is with the wrap is it safe to take off and just place the cells in the box/enclosure? I found this battery and it has with packaging, so the packing is the wrap? Thanks for the helpBattery size: 7.1 * 3.6 * 2.1cm / 2.8 * 1.4 * 0.8inBattery weight: 107g / 3.8ozNote: due to the difference between the measurement, the battery dimension and weight Package size: 12 * 5 * 3cm / 4.8 * 1.9 * 1.2inOr this Zippy 1300mah. Anyone know if the measurement is with or without wrap.Spec.Capacity: 1300mAhVoltage: 3S1P / 3 Cell / 11.1VDischarge: 25C Constant / 35C BurstWeight: 101g (including wire, plug & case)Dimensions: 76x19x35mmBalance Plug: JST-XHDischarge Plug: XT60
blueridgedog Posted November 4, 2015 Report Posted November 4, 2015 Most measurements in my experience are with the wrap...i.e. as the pack will be used. You can remove it, but if one mm of shrink wrap makes or breaks your install, you have very little room for failure. I will also add that most battery measurements have been "approximations" in my experience and have found some that are well undersized from the stated measurements.
