dusk1911 Posted November 24, 2015 Author Report Share Posted November 24, 2015 Hey I have a vaporshark, TC stops working when the device goes to sleep, only starts functioning again if the device is hard rebooted. This is quite annoying and i think its because of the 9-30 firmware, is there any way i can downgrade to test ? Link to comment Share on other sites More sharing options...
blueridgedog Posted November 24, 2015 Report Share Posted November 24, 2015 You can download earlier firmware from this thread:https://forum.evolvapor.com/topic/66731-topic/?do=findComment&comment=900118 Link to comment Share on other sites More sharing options...
dusk1911 Posted November 25, 2015 Author Report Share Posted November 25, 2015 Just an update, if i also switch to a regular kanthal profile and switch back it works ! , i have tested this on my Lavabox and 44 and they all do the same thing.Wire is 317L 24G resting at 0.2 Link to comment Share on other sites More sharing options...
cukrus Posted November 25, 2015 Report Share Posted November 25, 2015 happens to me as well. Good thing it is SS Link to comment Share on other sites More sharing options...
blueridgedog Posted December 2, 2015 Report Share Posted December 2, 2015 A good step in looking at this would be a device monitor screen shot after it goes to sleep showing resistance/wattage/temp then a comparative one after it is rebooted.What could be happening?:After sleep the board fails to see the combination of atomizer and wire as acceptable for TC mode, i.e. it can't detect enough resistance changes to conclude that it is TC wire.What could cause this?:Changes in atomizer resistance coupled with some atomizer state re-read from the sleep state.A programing defect in the board such that sleep mode triggers a non-tc state.If this is only with low TRC wire, then the first thing I would try and do is reproduce it with Ni200. If it can't be reproduced with higher TCR wire, then it is likely tied to the total TCR value of the wire used being on the margin of triggering TC mode and some issue with sleep triggering a state re-read. Link to comment Share on other sites More sharing options...
Halfthebottle Posted December 4, 2015 Report Share Posted December 4, 2015 Has happened to me as well on my Reuleaux, on a Ti coil. Picked up the mod and got half a lung full of scorching vapor. It doesn't appear to happen every time it wakes from sleep though, because I have left the mod over night and it has worked fine in the morning. But, in the 5 days I've had the mod, it has happened on three separate occasions. Other than this issue the board has been functioning perfectly, as far as I can tell.Anyone have any idea on fix for this? Link to comment Share on other sites More sharing options...
