Monitoring temp control dont show temperature
Hi,
  I have a reuleaux DNA 200 with a Herakles plus tank with SS coil.  I setup my profile for temp control and loaded the SS file.  Set the max temp to 450F and Watt at 50.  When I fire my mod the screen show --- as temp and also if I use monitor in escribe the temperature (yes it is clicked) does not show anything, its always ?.
Any idea?
Thanks.
Seems like it has not seen enough change in temp in the 1st second of firing, it backs out of temp limiting it the coil doesn't appear to raise 150 F in temperature.  Could be several things, most likely is the materials profile does not match the wire, it could also be a poor atty/connection.  SS is a very poor wire for temp limiting, it can work, but because it is not well suited to it you may/probably will need to have a lot of trial and error.
