omar said:
When i use this profile, my battery will charge till 98% only and cut off, it wont reach 100% unless i change the capacity to 14.43 WH. Should i leave it set 13.68WH or change to 14.43WH.
I got the Efusion on wed the 9th. updated the firmware and loaded the Efusion profile on it. I've been using ss 316l on a Kennedy with out issues exclusively so far.
I changed the battery to 14.43WH and it charges to 100%.
I have a dual coil 24g 316l, 3.0mm, 7 wraps each. comes out to 0.167 ohms according to escribe, and when I lock the resistance it locks at 0.17Ohm.
Temp is set to 450°, Wattage is set to 47.5w, 75w pre heat, with punch set to 5.
So far I'm really enjoying it. My only complaint is battery life. I'm a heavy vaper and go through about 20ml of juice a day so I charge off and on through the day.
Hope this info helps some of you with the ss temp issues.
Now im having an issue with effusion..my 1st mod work like charm for 2 days then suddenly blank.. then i return to the store for exchange..after 2 month use like a champ..but today its happen again..no screen but will power up when usb plug in..suspect the fuse blow..oh im so tired with this kind of problem..not sure dna board problem or lost vape problem..
