CrashRecovery Posted December 29, 2015 Author Report Posted December 29, 2015 So I was going through the escribe software and saw that the battery rating was not the correct size for what is in my lavabox. So when I changed it to 900 from 700. The first time I did a full charge it never went to 100%. I think it was at 97%. Do I need to adjust anything else or do I need to run the battery program?
Spector NS5 RD Posted December 29, 2015 Report Posted December 29, 2015 900 to 700? in the watt hour field type in 10.08. that's what i got when i ran battery analyzer. that seems to be more accurate. i'm almost positive the lavabox uses a fullymax 900 mah lipo. that's also the same battery i ran the battery analyzer with. i recommend running batt analyzer for yourself at an avg wattage you vape at for an accurate battery meter. i have noticed sometimes my devices will never get to 100% when usb charging. i fire the mod once while still plugged into a charger and that kicks the charging cycle back into gear and gets me to 99-100%.
CrashRecovery Posted December 29, 2015 Author Report Posted December 29, 2015 The first setting was 700 I put it to 900. That's when it stopped "fully" charging
Spector NS5 RD Posted December 30, 2015 Report Posted December 30, 2015 where did you input 900? at the watt hour field in manufactures settings under the mod tab? 900 would be telling your dna 200 you have a 900 watt hour battery, lol. take a screen shot of this 900 number in whatever field you have it in. and post it here. i dunno if youre using the watt hour calculator and using that number or what, but 900 would be the mah of the lipo, which would equate to 10 watt hours using escribe's calculator.
CrashRecovery Posted December 30, 2015 Author Report Posted December 30, 2015 So I just opened escribe and noticed that option isn't available in the new version of the software. But the watt hour calculator was using 720 not 900. Maybe that was the issue
Vaportron Posted December 30, 2015 Report Posted December 30, 2015 I think you just have to hit the expand Button and it will all pop up again. Definately need to fix that!
CrashRecovery Posted December 30, 2015 Author Report Posted December 30, 2015 I fixed the numbers in the watt calculator to 900, so that should be good to go now. I'll let it charge up and see what it goes to.
Spector NS5 RD Posted December 30, 2015 Report Posted December 30, 2015 this is what should be input for your watt hour field or 9.9 using the calculator. either one will be ok to use. just making sure you don't have the wrong number in there.
CrashRecovery Posted December 30, 2015 Author Report Posted December 30, 2015 I've just used the 9.99 the calculator came up with. oh and I'm not sure how familiar you are with lipos but from using them in my r/c planes I wont take my lipos under 3v. anything under that and you are pushing the service life of a lipo. just saying
Spector NS5 RD Posted December 30, 2015 Report Posted December 30, 2015 i just typed 10 in there for you to see where it goes. if you look on my battery curve you'll notice the watt hour is actually 28.XX. That screen shot (purely for demonstration purposes) is for my triple 18650 LG HG2 reuleaux. all my other dna200's with lipos are set at 3.09v for the cutoff.
CrashRecovery Posted December 30, 2015 Author Report Posted December 30, 2015 ChunkyButt200 said: is for my triple 18650 LG HG2 reuleaux. all my other dna200's with lipos are set at 3.09v for the cutoff. Phew...... ive seen too many lipo fires from people trying to recover low voltage lipos
