Kahless Posted August 24, 2015 Author Report Posted August 24, 2015 Hi,I received my first DNA200 mod today the VTBox200 and read in the manual not to allow the cell's to go below 3.6V. It has a 3c lipo 1800mAh 11.1V 35C in it.The standard soft cell cut-off is 3.09V in the software but I have had to change it to 3.6 on my device due to the manual.Does anyone have any idea if I can use the 3.09V or should I go with what it says? It is effectively a 1500mAh battery if I set it to 3.6V (which some people have suspected it is on the internet, not that I believe everything I read on there but it does stack up with the physical size of the battery)Anyone any idea'sThanks in advanceRobert
Brandon Posted August 26, 2015 Report Posted August 26, 2015 Hi Robert,I think that may be a typo or just plain nonsense. From the pictures I saw of the pack, it is a standard 3 cell Li-PO and an under load cut off of 3.09 should be fine. 3.2v would probably extend the batteries life a bit but 3.6v seems high.
Kahless Posted August 26, 2015 Author Report Posted August 26, 2015 Hi Brandon. Thanks for the reply. When you say under load cut off is this the same as the soft cell cut off in escribe? Thanks Robert
dion81@live.com Posted December 31, 2015 Report Posted December 31, 2015 I just bought the lava box. what it the lowest cutoff would yall recommend for maximum battery life and what type of battery does this box have lith or lifePo
VapingBad Posted December 31, 2015 Report Posted December 31, 2015 Are you sure it is a LiFePo I thought they were LiPo, they operate at different voltages to LiPos and you need to get this right, but the default is fine for both 3.09 V for LiPo and 2.7 V for LiFePo.
