JLWells1013 Posted December 29, 2015 Author Report Posted December 29, 2015 Ok, so I just got this device and I'm unsure exactly what battery option to choose in the software. I've watched a few reviewers of the device and all they touch on is how to change the watt hours. All it says in the user manual is that it's a FullyMax 1300mah 3S Lipo battery. Do I select lithium polymer in the software?
VapingBad Posted December 29, 2015 Report Posted December 29, 2015 Yes, LiPo and put 1300 mAh with 11.1 V in the What hour calc, but I think there is an official settings file for these, yes see https://forum.evolvapor.com/topic/67562-topic/
JLWells1013 Posted December 29, 2015 Author Report Posted December 29, 2015 Thanks! And, I've uploaded those settings. I just wanted to make absolutely certain everything was entered in properly. One more question, though. Is there a reason why the device would not be asking me if I'm attaching a new atomizer? I mean, it's asked me maybe three times since I got which was December 23rd, and I've attached and reattached two different atomizers several times and the screen simply doesn't prompt me. I have profiles set up for both atomizers, of course, but with one of them being a nickel coil, I feel like it should ask me. Also, it will fire the nickel coil in power mode if I do not manually switch to temp mode. Is that supposed to happen?
VapingBad Posted December 29, 2015 Report Posted December 29, 2015 If it can be sure it it a new atty it does not ask, if the res is close it will, you can change how close on the mod tab in EScribe.
JLWells1013 Posted December 29, 2015 Author Report Posted December 29, 2015 By the way, the mod resistance is set at 0.006 and the atomizer is 0.21. Should it be prompting me?
JLWells1013 Posted December 29, 2015 Author Report Posted December 29, 2015 And about it firing a nickel coil in power mode...should it switch to temp automatically?
Rcarter Posted January 3, 2016 Report Posted January 3, 2016 There is no such thing as "power mode" on the 200. Unless you have the temperature limit set to "off", it will automatically detect and start measuring temperature when it detects on is attached.
