Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 I have one of your DNA200 boards and I have a temp control issue, I get hot spots no matter what I try, even if I turn it all the way down to 400F. After looking on the forum, I could see someone said to try a single coil and make sure it is well spaced, I did this and I have the exact same problem. I made sure the RDA was left to cool before attaching, and I also ensured the resistance was nice and stable on by build. Any ideas? Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2016 Report Share Posted January 7, 2016 What wire are you using Tom? Link to comment Share on other sites More sharing options...
Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 Hi,I am using NI200 wire, 28AWG Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2016 Report Share Posted January 7, 2016 You are doing the right things and shouldn't be getting the hot spots, I would re-tighten the coils and clean both sides of the 510 then if that doesn't work try a different atomiser. Link to comment Share on other sites More sharing options...
Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 I tried three builds on it so far, ill try a different RDA and see if that helps.Earlier today when i had 2 coils in, i noticed it wasnt showing any temp on screen when i fired it either so something it up.This RDA works fine on my DNA40 though which is weird. Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2016 Report Share Posted January 7, 2016 When it does not show the temp it is normally because it doesn't sense a temperature raise of 150 F in the first second. Is your mod resistance set high? zero is better that too high. Link to comment Share on other sites More sharing options...
Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 well the resistance on the coil was 0.18, i have not changed anything in the eScribe by the way.It was very over 150F i can assure you, the vapor roasted my tongue a slightly Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2016 Report Share Posted January 7, 2016 Tom said: well the resistance on the coil was 0.18, i have not changed anything in the eScribe by the way. Expand In EScribe on the Mod tab under Manufacture settings check that it is below 0.010, even that is high IMO all my mods are < 0.004 ohm. If it is set it is worth zeroing it (take a note of the value first) to see if that helps. Link to comment Share on other sites More sharing options...
Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 Well its set to 0, i just tried it again and this time its working. I wonder if it just needed more time to cool or something, but so far its working as expected.By the way, any idea what this chip is? when my board came, it was lifted up from the board, like it was on a hinge which was strange. I just wondered if this chip might be causing some issues if it was damaged. Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2016 Report Share Posted January 7, 2016 It is an inductor not a chip, if it were me I would return it to the vendor as it seem it took a knock during manufacture.This may be of interest https://forum.evolvapor.com/topic/67527-topic/ Link to comment Share on other sites More sharing options...
Tom Posted January 7, 2016 Author Report Share Posted January 7, 2016 ok thanks ill see what they can do for me Link to comment Share on other sites More sharing options...
