mactavish Posted November 4, 2015 Author Report Posted November 4, 2015 Thought I'd create a thread where: LavaBox DNA200 owners can post their own "Case Analyzer" results, to compare.Took a few hours to run, and these were my results:CASE COOLING TIME CONSTANT: 423.64CASE HEATING TIME CONSTANT: 736/44CASE USB CHANGE TEMPERATURE RISE: 11.25 F19.73 F/A
cukrus Posted November 4, 2015 Report Posted November 4, 2015 I just started mine. It'll go for 6 hours or so
Margucci Posted November 7, 2015 Report Posted November 7, 2015 i ran my test with a room temp at about 71*FCASE COOLING TIME CONSTANT: 933.22CASE HEATING TIME CONSTANT: 308.27CASE USB CHANGE TEMPERATURE RISE: 4.34 F9.8 F/A
Tepid Posted November 27, 2015 Report Posted November 27, 2015 I ran the test at 75*FAccording to Atomizer Analyzer the Room Temp was 76*FHowever, this test may be inaccurate. I ran it when it was almost fully chargedI will run it again when it is about half charge.The test took about 2.5 to 3 hours.Also note, I Loaded the CSV Battery file from hereAnd I also set theseBattery Capacity: 9.99WhSoft Cell Cutoff: 3.09vMod Internal Resistance: 0.007 OhmsBased on what I am seeing and from others posting their results for other mods.It's hard to say how accurate the Case Analyzer actually is.Room Temp, if this is not constant everywhere you decide to vape and charge, these numbers very well could changeThis could cause big fluctuations. Right now, my Room temp from Atomizer Analyzer shows 65*F, but, I am in the same room I was in when I ran it the first time.Yes, I believe that Temp is correct though. it is colder in here than when I ran it before.I will run it 2 more times, and I will check both the Atomizer Analyzer and a Thermometer in this room and average the temp from that to run at.Also, the next tests will be run at half charge, and the mod will sit in this room pretty much over night and then run the test.If the results are drastically different, then I could only surmise that Case Analyzer may be kinda useless, as these settings can change based on the actual temp of the mod at any given timeSuch as, you have it in your pocket, it's gonna heat up a bit, so, where the Analyzer and Thermal settings were set based on a Mod Temp of 70*F, you might be running it at a temp of 85*FHow this takes into account settings based on Case Temps and Ambient Temps at any given time, I don't see how this could stay accurate.CASE COOLING TIME CONSTANT: 1623.94 ,,, but this was rounded down to 1000CASE HEATING TIME CONSTANT: 170.19CASE USB CHANGE TEMPERATURE RISE: 0.71 F28.00 F/A
Tepid Posted December 2, 2015 Report Posted December 2, 2015 I did not run this twice, but new numbersThis one is probably a bit more accurateI started it with about 45% batteryRan at 82*F Room TempCASE COOLING TIME CONSTANT: 1521.32 ,,, but this was rounded down to 1000CASE HEATING TIME CONSTANT: 753.92CASE USB CHANGE TEMPERATURE RISE: 1.32 F16.71 F/A
jarred.sayles Posted February 7, 2016 Report Posted February 7, 2016 Ran Mine at 72°f Only had about 30% charge Cooling constant 549.09 s Heating constant 714.95 s USB Change Temp Rise 7.44°F 14.45°F/A
jarred.sayles Posted February 7, 2016 Report Posted February 7, 2016 When I asked the volcano rep the case thermals their cooling time constant value was higher than their heating time constant. Where all of ours is the opposite. Anyone have any idea why that is?
Margucci Posted February 7, 2016 Report Posted February 7, 2016 no idea. i dont trust any of the configuration dont by volcano. they just had the defaults for months. just make sure that your case resistance is set to 0.007 and then run the battery and case analyzer. use the results you get. they will be the best.
jarred.sayles Posted February 8, 2016 Report Posted February 8, 2016 Thats what I'm gonna do. I'm gonna run my case thermals 1 or 2 mode times and see if the values are close and if so. Take an avg. number of the values.
Bobw1951 Posted February 14, 2016 Report Posted February 14, 2016 Just did an analysis @ Room Temp 73.58FSome of the figures in above comments look quite crazy, the test runs for 3 hours 40 minutes and the mod must be left alone whilst the test is being carried out.The 1st hour is to allow the Temp to settle, the next charges @ 0.50A for 1 hour, then cools for 1 hour, it then does 10 minutes each of charging & cooling @ 0.10A and 0.30A before giving you the results to accept & then upload to your device
Zfkirke0109 Posted February 18, 2016 Report Posted February 18, 2016 I did mine at 68 degree's because that's what the thermostat said and this is what I got. Did I do this wrong?
