JTree Posted March 1, 2016 Author Report Posted March 1, 2016 Hmmm.....do I have a bad battery or is there something going on with the board? Correct me if I'm wrong, but shouldn't it be drawing close to 1A with the cells so balanced and so close to being discharged? Also, is it common for the incoming amperage to be so......janky? It's also discharging at a ridiculous rate.....1/3 charge down to 10% in 5 moderate length puffs in TC mode.
dwcraig1 Posted March 1, 2016 Report Posted March 1, 2016 On the charge rate if plugged into a computer and the mod sees a data path a .5 amp rate is the most you will get.
JTree Posted March 1, 2016 Author Report Posted March 1, 2016 ah.....ok.....that makes sense. Come to think of it, I remember something about data connection and .5A from somewhere. Is that a common trait of many electronic devices? I'm obviously not very knowledgeable in this field, but I find it fascinating.
DRTMI Posted March 2, 2016 Report Posted March 2, 2016 JTree said:ah.....ok.....that makes sense. Come to think of it, I remember something about data connection and .5A from somewhere. Is that a common trait of many electronic devices? I'm obviously not very knowledgeable in this field, but I find it fascinating.Your computer can only put 500mAh which is .5a
