stcolley Posted March 4, 2016 Author Report Posted March 4, 2016 Hi AllCould anyone shed some light on this issue?I charge the device next to my bedside and while the device is charging the display comes on at firing brighness (100%) every few minutes.The display brightness is set 0% (off) for charging screen in escribe.Now ive only recently been charging the device next to me, so i cannot tell if it is a new issue with the latest 23rd February firmware or if it has done this all the time.Hope to hear from someone soon!!
VapingBad Posted March 4, 2016 Report Posted March 4, 2016 I would try different USB power supplies and cables first as if there is an intermittent supply the display would light like it does when you first plug it in. I would also want to be sure it is not actually firing and return it if it is.
stcolley Posted March 4, 2016 Author Report Posted March 4, 2016 Hi VapingBadThanks for replying so fast. I tried two different 0.5A and a 1A charger and its the same. I didn't try a different cable as i use this cable for other things too, but having said that maybe the DNA200 is picking up or exhibiting symptoms other devices do not and hence it may be a faulty cable. I will give it a try thanks. LOL when it first happened i jumped up and felt/smelt if it fired and it was ice cold so thankfully that is not the case.Will let you know,Cheers for now
