Shadowjump Posted March 5, 2016 Author Report Share Posted March 5, 2016 I noticed a few days ago that with two different sets of 3x LG HG2, the cell cut off voltage of 3.2 is not working and when It reaches around 3.35v it says weak battery and the wattage drops. Anyone know why this is happening? The batteries have less than 30 charge cycles. Link to comment Share on other sites More sharing options...
VapingBad Posted March 5, 2016 Report Share Posted March 5, 2016 If you look at it firing on Device Monitor you should see that it is sagging to 3.2 V under load, if you are at high power those batteries will have a larger sag than HE2s, 25Rs and VTCs. Link to comment Share on other sites More sharing options...
Shadowjump Posted March 5, 2016 Author Report Share Posted March 5, 2016 So the cutoff is applied under load? Link to comment Share on other sites More sharing options...
VapingBad Posted March 5, 2016 Report Share Posted March 5, 2016 Shadowjump said:So the cutoff is applied under load?Yes, so the batteries will be higher when you remove them. Link to comment Share on other sites More sharing options...
