Smokin1337 Posted February 27, 2016 Author Report Posted February 27, 2016 I would like to see independent display settings, meaning the display fields can be changed for each profile. When I run temp I want to see my ohms, wattage, battery percent and temp, but when I am i wattage/power mode I want to see ohms, voltage, battery percent and wattage. Currently you set your display fields and it stays the same for all prpfiles. Thanks
BillW50 Posted March 30, 2016 Report Posted March 30, 2016 Since Temperature Dominant toggle has been added, that was a game changer for me and freed up the temperature field. We never needed it for power mode and it was just a waste. And in TC mode, we needed it because most of us leave wattage set and adjust by temperature. So we need to watch temperature and not wattage. With Temperature Dominant, that field is now wide open.
