PapaSmurf81 Posted March 31, 2016 Author Report Posted March 31, 2016 I bought a lavabox from a friend that was missing a screen and needed a new battery. Checked battery on an external balance charger and cell 1 was at 1.91v, tried a rebalance charge and it did nothing so i have replaced the battery for a Turnigy Nanotech 3s 11.1v which i tested on the balance charger and all cells read 3.86v. I installed the battery and went to escribe and updated battery config for the new battery and uploaded it to the lavabox. I then checked Device monitor, it is saying cell 1 is 3.72v cell 2 is 4.25v and cell 3 is 3.89v ?? Is my board cooked? or have i messed up the settings somewhere?
dwcraig1 Posted March 31, 2016 Report Posted March 31, 2016 I'm afraid I can't be much help but I'm thinking that you mean that you checked the voltage on each cell on the balance connector with a meter, is that correct?Did this board by chance get juice leaked on the bottom of the board at the balance connector?
PapaSmurf81 Posted March 31, 2016 Author Report Posted March 31, 2016 Yes i tested my new battery on an external tester and the cells were tested as all balanced, when i check with it in my lavabox it is reading as very unbalanced.
dwcraig1 Posted March 31, 2016 Report Posted March 31, 2016 Does the mod appear to work properly otherwise?
PapaSmurf81 Posted March 31, 2016 Author Report Posted March 31, 2016 No matter, fixed it, there was a chip with a small blob of juice on it. Cleaned it off with isopropyl alcohol and put it back together. working perfect now Thanks guys
