xevape Posted December 12, 2015 Author Report Posted December 12, 2015 So basically I was tasked with stripping a DNA 200 from a 2A vaporshark and found some interesting components and differences. I then decided to see if the 1A board could house the LED's, the same LED functionality as the 2A chip and found that they are all looped together but if you add all 3 LED's you get the fire and charge functionality. https://www.instagram.com/p/_LMA9LgWKh/top LED is GROUND/POSITIVEbottom left is GROUND/POSITIVEbottom right is POSITIVE/GROUND If you need more guidance or are interested in adding LED's just hit me up it was pretty simple.
Spirometry Posted December 12, 2015 Report Posted December 12, 2015 https://forum.evolvapor.com/topic/66518-topic/?do=findComment&comment=897999
Spector NS5 RD Posted December 12, 2015 Report Posted December 12, 2015 xevape said:So basically I was tasked with stripping a DNA 200 from a 2A vaporshark and found some interesting components and differences. I then decided to see if the 1A board could house the LED's, the same LED functionality as the 2A chip and found that they are all looped together but if you add all 3 LED's you get the fire and charge functionality. https://www.instagram.com/p/_LMA9LgWKh/top LED is GROUND/POSITIVEbottom left is GROUND/POSITIVEbottom right is POSITIVE/GROUND If you need more guidance or are interested in adding LED's just hit me up it was pretty simple.hey xevape can you post some more pics of that vs board. im trying to find the differences in components for the charging circuits. 1a vs 2a. evolv said the vs board is slightly longer and has different charging components.
jurdanas Posted December 12, 2015 Report Posted December 12, 2015 "xevape"COOL. Thank you. I understand , but which use "LED" model? "smd 0603 ??????" ? Please, if you can.
xevape Posted December 12, 2015 Author Report Posted December 12, 2015 jurdanas said:"xevape"COOL. Thank you. I understand , but which use "LED" model? "smd 0603 ??????" ? Please, if you can.Yes
jurdanas Posted December 13, 2015 Report Posted December 13, 2015 xevape said:[QUOTE=jurdanas]"xevape"COOL. Thank you. I understand , but which use "LED" model? "smd 0603 ??????" ? Please, if you can.Yes[/QUOTE]Not full answer . SMD0603 have about 240 manufacturer model. http://eu.mouser.com/Optoelectronics/LED-Indication/_/N-b1d1k?Keyword=led+smd+0603&FS=Truehttp://uk.farnell.com/webapp/wcs/stores/servlet/Search?pageSize=25&st=led+smd+0603&catalogId=15001&categoryId=700000006139&langId=44&storeId=10151Thank you.
xevape Posted December 13, 2015 Author Report Posted December 13, 2015 jurdanas said:[QUOTE=xevape][QUOTE=jurdanas]"xevape"COOL. Thank you. I understand , but which use "LED" model? "smd 0603 ??????" ? Please, if you can.Yes[/QUOTE]Not full answer . SMD0603 have about 240 manufacturer model. http://eu.mouser.com/Optoelectronics/LED-Indication/_/N-b1d1k?Keyword=led+smd+0603&FS=Truehttp://uk.farnell.com/webapp/wcs/stores/servlet/Search?pageSize=25&st=led+smd+0603&catalogId=15001&categoryId=700000006139&langId=44&storeId=10151Thank you.[/QUOTE]Lens Color/Style = Water Clear Orientation = Top View Package / Case = 0603 Mounting Style = SMD/SMT
Ratboy0883 Posted March 31, 2016 Report Posted March 31, 2016 xevape said:So basically I was tasked with stripping a DNA 200 from a 2A vaporshark and found some interesting components and differences. I then decided to see if the 1A board could house the LED's, the same LED functionality as the 2A chip and found that they are all looped together but if you add all 3 LED's you get the fire and charge functionality. https://www.instagram.com/p/_LMA9LgWKh/top LED is GROUND/POSITIVEbottom left is GROUND/POSITIVEbottom right is POSITIVE/GROUND If you need more guidance or are interested in adding LED's just hit me up it was pretty simple.Thank you for the board pictures. I have looked at your Instagram and did not find my answer. If you could recall I would greatly appreciate it.The vaporshark is said to have a green fully charged LED, I do not recall if mine ever did but it does not now. I believe it must be a bipolar green/red in the charge position. Do you recall if it is the same LED? I am attempting to confirm before probing as I do not have a good mini probe rig.Thank you for any help.
Guest Posted March 31, 2016 Report Posted March 31, 2016 A closer shot of the LEDs would be nice to see if this is what it is
Spector NS5 RD Posted April 1, 2016 Report Posted April 1, 2016 Ratboy0883 said:Thank you for the board pictures. I have looked at your Instagram and did not find my answer. If you could recall I would greatly appreciate it.The vaporshark is said to have a green fully charged LED, I do not recall if mine ever did but it does not now. I believe it must be a bipolar green/red in the charge position. Do you recall if it is the same LED? I am attempting to confirm before probing as I do not have a good mini probe rig.Thank you for any help.the vaporshark dna 200 does not have a green led. blue when fire button is pressed. red while charging. nothing (red led turns off) when fully charged.
Ratboy0883 Posted April 1, 2016 Report Posted April 1, 2016 So the green is only on the earlier versions and not in the 200? Thank you ChunkyButt200, I wish this was more clear on vaporshark website. They refer to green on all others but don't mention LEDs for DNA200.
Spector NS5 RD Posted April 1, 2016 Report Posted April 1, 2016 Ratboy0883 said:So the green is only on the earlier versions and not in the 200? Thank you ChunkyButt200, I wish this was more clear on vaporshark website. They refer to green on all others but don't mention LEDs for DNA200.correct, @Ratboy0883. no green led's on the dna 200. 2 blue, 1 red that's it.
periclesharalambidis1 Posted February 16, 2022 Report Posted February 16, 2022 whats easy way to rier a push botton led so it lights whenits fierd do you have a diagram leme know
