pepepe Posted April 9, 2016 Author Report Posted April 9, 2016 After breaking an oring of the tank I had liquid discharge inside the box , I dried immediately and runs everything except the USB data link, it jumping continuously . PC many times tells me unrecognized device , or connect with e cig stats and disconnects after 2 seconds, into ecig stats appear a message below that says the device is being used by another program. What can cause this conflict? I think it is impossible that it is only the damaged part data usb ,charging works perfectly.
dwcraig1 Posted April 9, 2016 Report Posted April 9, 2016 This thread may be of interest to you. https://forum.evolvapor.com/topic/67136-topic/?do=findComment&comment=904285for the complete thread:https://evolvapor.forumchitchat.com/post?id=8065639
pepepe Posted April 9, 2016 Author Report Posted April 9, 2016 I had already read this post , but I do not think matches, i would just like to know if Usb can be partially damaged or do bad contact and the rest to recharge the box normally.
Spector NS5 RD Posted April 9, 2016 Report Posted April 9, 2016 pepepe said: I had already read this post , but I do not think matches, i would just like to know if Usb can be partially damaged or do bad contact and the rest to recharge the box normally.try a pcb safe solvent and give the usb a good cleaning. there's probably ejuice in places where your eyes cannot see. @dwcraig1 could give you some pointers on cleaning the usb area. he had a similar problem. board should be fine once ejuice is removed completely.
dwcraig1 Posted April 9, 2016 Report Posted April 9, 2016 Juice is able to conduct small amounts of current, I had juice under the balance plug on the board once and it slowly drained cell #3. I cleaned mine off in that area with no clean flux and a few bursts of canned PC duster spray.
pepepe Posted April 9, 2016 Author Report Posted April 9, 2016 SOLVED!!! Thx!!!Thats right, the issue was caused by eliquid, it created a bad contact.I Bought a cleaner for contacts (CRC contact cleaner), spraying it directly on the board and with the help of a brush I restored everything.
