Check Atomizer Error
Hey!
Just put together a mod and everything is well except something has got to be up with my 510 Varitubes...I get the check atomizer error everytime I try to fire...everything is connected correctly...anyone ever have this problem??
No, but it is easy to do a dry solder joint in the positive than you would think, I would expect it is not showing any resistance in device monitor either.  If it is a common ground design that could also be the cause.  I would start by checking the continuity or resistance with a metre
